# MQTT Binding
- EspMilightHub Binding
- HomeAssistant MQTT Components Binding
- MQTT Homie Binding
- Ruuvi Gateway MQTT Binding
# Supported Bridges
# Bridge Configuration
- hostnameValidated: Validate hostname from certificate against server hostname for secure connection. Defaults to true.
- protocol: The protocol used for communicating with the broker (TCP, WEBSOCKETS). Defaults to TCP.
- mqttVersion: The MQTT version used for communicating with the broker (V3, V5). Defaults to V3.
Reconnect parameters are:
- lwtRetain: Retain last will message. Defaults to true.
An MQTT message can be published upon a successful connection to the MQTT broker with these parameters:
- birthMessage: An optional message to be published once the bridge established a connection to the MQTT broker. Defaults to empty.
- birthTopic: The birth topic. Defaults to empty and therefore no birth message will be published.
- birthRetain: Retain the birth message. Defaults to true.
An MQTT message can be published just before disconnecting from the broker with these parameters:
- shutdownMessage: An optional message to be published before the bridge disconnects from the MQTT broker. Defaults to empty.
- shutdownTopic: The shutdown topic. Defaults to empty and therefore no shutdown message will be published.
- shutdownRetain: Retain the shutdown message. Defaults to true.
# Supported Channels
Configuration parameters are:
