# Qolsys IQ Binding
This binding directly controls a Qolsys IQ (opens new window) security panel. This allows for local monitoring of alarm and zone statuses as well as arming, disarming and triggering alarms.
Qolsys (a division of Johnson Controls) is a popular manufacturer of alarm systems. The Qolsys IQ line of panels supports both wireless and hard wire sensors and features built in Cellular and Wi-Fi dual path communication that natively integrates with Alarm.com (opens new window) monitoring and supervision.
This binding directly interfaces with the panel and does not require cloud access.
Qolsys IQ 4
Thing Description Thing Type Thing UID
Qolsys IQ Panel A Qolsys IQ security panel (all current models, which is 2+ and 4 at the time of writing) Bridge panel
Qolsys IQ Partition A logical partition which can be armed, disarmed, and is responsible for managing zones Bridge partition
Qolsys IQ Zone A generic zone sensor Thing zone
# Qolsys IQ Panel (Bridge)
The Qolsys IQ Panel must be manually added using a host name or ip address along with a secure access token from the panel settings. To enable 3rd party control and retrieve the access token follow the following steps on the security panel touch screen:
Settings --> Advanced Settings --> Installation --> Dealer Settings -> 6 Digit User Code (set to enabled)
Settings --> Advanced Settings --> Installation --> Devices --> Wi-Fi Devices --> Control4 (set to enabled)
Panel will reboot
Settings --> Advanced Settings --> Installation --> Devices --> Wi-Fi Devices --> Reveal Secure Token (copy token to use in panel configuration)
At this point you may add the panel thing in openHAB using the secure token along with the IP or host name of the panel.
# Partition (Bridge)
Once a panel is added, partitions will be automatically discovered and appear in the inbox.
# Zone (Thing)
Once a partition is added, zones will be automatically discovered and appear in the inbox.
# panel Thing Configuration
Name Type Description Default Required Advanced
hostname text Hostname or IP address of the device N/A yes no
port integer Port the device is listening on 12345 no no
key text Access token / key found in the panel settings menu N/A yes no
# partition Thing Configuration
id integer Partition id of the panel, staring with '0' for the first partition N/A yes no
disarmCode text Optional disarm code to use when receiving a disarm command without a code. Required for integrations like Alexa and Homekit who do not provide codes when disarming. Leave blank to always require a code blank no no
armCode text Optional arm code to use when receiving arm commands without a code. Only required if the panel has been configured to require arm codes. Leave blank to always require a code blank no yes
# zone Thing Configuration
id integer Id of the zone, staring with '1' for the first zone N/A yes no
# Panel Channels
None.
# Partition Channels
Channel Type Read/Write Description State Options Command Options
armState String RW Reports the current partition arm state or sends an arm or disarm command to the system. Security codes can be appended to the command using a colon delimiter (e.g. 'DISARM:123456'). Codes appended to the command will be used in place of the armCode configuration property if set. ALARM, ARM_AWAY, ARM_STAY, DISARM, ENTRY_DELAY, EXIT_DELAY ARM_AWAY, ARM_STAY, DISARM
alarmState String RW Reports on the current alarm state, or triggers an instant alarm AUXILIARY, FIRE, POLICE, ZONEOPEN, NONE AUXILIARY, FIRE, POLICE
armingDelay Number R The arming delay countdown currently in progress Seconds remaining N/A
errorEvent String R Last error event message reported by the partition. Clears after 30 seconds Error text N/A
# Zone Channels
status String R The zone status ACTIVE, CLOSED, OPEN, FAILURE, IDLE, TAMPER
state Number R The zone state Number
contact Contact R The zone contact state OPEN, CLOSED
# qolsysiq.things
Bridge qolsysiq:panel:home "Home Security Panel" [ hostname="192.168.3.123", port=12345, key="AAABBB00" ] {
    Bridge partition 0 "Partition Main" [ id=0, armCode="123456" ] {
        Thing zone 1 "Window" [ id=1 ]
        Thing zone 2 "Motion" [ id=2 ]
# qolsysiq.items
Sample items file with both Alexa and Homekit voice control
Group      PartitionMain                         "Alarm System"                                                           ["Equipment"]    {alexa="SecurityPanel", homekit = "SecuritySystem"}
String     PartitionMain_PartitionArmState       "Partition Arm State"                <Alarm>    (PartitionMain)          ["Point"]        {channel="qolsysiq:partition:home:0:armState", alexa="ArmState" [DISARMED="DISARM",ARMED_STAY="ARM_STAY",ARMED_AWAY="ARM_AWAY:EXIT_DELAY"], homekit = "SecuritySystem.CurrentSecuritySystemState,SecuritySystem.TargetSecuritySystemState" [STAY_ARM="ARM_STAY", AWAY_ARM="ARM_AWAY", DISARM="DISARM", DISARMED="DISARM", TRIGGERED="ALARM"]}
String     PartitionMain_PartitionAlarmState     "Partition Alarm State"              <Alarm>    (PartitionMain)          ["Point"]        {channel="qolsysiq:partition:home:0:alarmState"}
Number     PartitionMain_PartitionArmingDelay    "Partition Arming Delay"                        (PartitionMain)          ["Point"]        {channel="qolsysiq:partition:home:0:armingDelay"}
String     PartitionMain_ErrorEvent              "Error Event"                                   (PartitionMain)          ["Point"]        {channel="qolsysiq:partition:home:0:errorEvent" }
Group      ZoneKitchenWindows                    "Qolsys IQ Zone: Kitchen Windows"                                        ["Equipment"]
Number     ZoneKitchenWindows_ZoneState          "Kitchen Windows Zone State"                    (ZoneKitchenWindows)     ["Point"]        {channel="qolsysiq:zone:home:0:1:state"}
String     ZoneKitchenWindows_ZoneStatus         "Kitchen Windows Zone Status"                   (ZoneKitchenWindows)     ["Point"]        {channel="qolsysiq:zone:home:0:1:status"}
Contact    ZoneKitchenWindows_ZoneContact        "Kitchen Windows Zone Contact"                  (ZoneKitchenWindows)     ["Point"]        {channel="qolsysiq:zone:home:0:1:contact"}
Group      ZoneMotionDetector1                   "Motion Detector 1"                                                      ["Equipment"]
Number     ZoneMotionDetector_ZoneState1         "Motion Detector 1 Zone State"                  (ZoneMotionDetector1)    ["Point"]        {channel="qolsysiq:zone:home:0:2:state"}
String     ZoneMotionDetector_ZoneStatus1        "Motion Detector 1 Zone Status"                 (ZoneMotionDetector1)    ["Point"]        {channel="qolsysiq:zone:home:0:2:status"}
