MQTT Architecture
  • When a device (a client) wants to send data to the broker, we call this operation a “publish”.
  • When a device (a client) wants to receive data from the broker, we call this operation a “subscribe”.
Publish and Subscribe
# MQTT Topics
Because every manufacturer can decide on his own on which topic his devices publish, this binding can unfortunately not provide any auto-discovery means.
The following optional parameters can be set for the Thing:
  • availabilityTopic: The MQTT topic that represents the availability of the thing. This can be the thing's LWT topic.
  • payloadAvailable: Payload of the Availability Topic, when the device is available. Default: ON.
  • payloadNotAvailable: Payload of the Availability Topic, when the device is not available. Default: OFF.
  • transformationPattern: An optional transformation pattern like JSONPath (opens new window) that is applied to the incoming availability payload. Transformations can be chained by separating them with the mathematical intersection character "∩". The result of the transformations is then checked against payloadAvailable and payloadNotAvailable.
# Supported Channels
  • string: This channel can show the received text on the given topic and can send text to a given topic.
  • number: This channel can show the received number on the given topic and can send a number to a given topic. It can have a min, max and step values.
  • dimmer: This channel handles numeric values as percentages. It can have min, max and step values.
  • contact: This channel represents an open/close state of a given topic.
  • switch: This channel represents an on/off state of a given topic and can send an on/off value to a given topic.
  • colorRGB: This channel handles color values in RGB format. (Deprecated)
  • colorHSB: This channel handles color values in HSB format. (Deprecated)
  • color: This channel handles color values in HSB, RGB or xyY (x,y,brightness) formats.
  • image: This channel handles binary images in common java supported formats (bmp,jpg,png).
  • datetime: This channel handles date/time values.
  • rollershutter: This channel is for rollershutters.
# Channel Configuration
  • stateTopic: The MQTT topic that represents the state of the thing. This can be empty, the thing channel will be a state-less trigger then. You can use a wildcard topic like "sensors/+/event" to retrieve state from multiple MQTT topics.
  • transformationPattern: An optional transformation pattern like JSONPath (opens new window) that is applied to all incoming MQTT values.
  • transformationPatternOut: An optional transformation pattern like JSONPath (opens new window) that is applied before publishing a value to MQTT.
  • commandTopic: The MQTT topic that commands are send to. This can be empty, the thing channel will be read-only then. Transformations are not applied for sending data.
  • formatBeforePublish: Format a value before it is published to the MQTT broker. The default is to just pass the channel/item state. If you want to apply a prefix, say "MYCOLOR,", you would use "MYCOLOR,%s". Currently only "%s" is supported.
  • postCommand: If true, the received MQTT value will not only update the state of linked items, but command it. The default is false. You usually need this to be true if your item is also linked to another channel, say a KNX actor, and you want a received MQTT payload to command that KNX actor.
  • retained: The value will be published to the command topic as retained message. A retained value stays on the broker and can even be seen by MQTT clients that are subscribing at a later point in time.
  • qos: QoS of this channel. Overrides the connection QoS (defined in broker connection).
  • trigger: If true, the state topic will not update a state, but trigger a channel instead.
# Channel Type "string"
  • allowedStates: An optional comma separated list of allowed states. Example: "ONE,TWO,THREE"
# Channel Type "number"
  • min: An optional minimum value.
  • max: An optional maximum value.
  • step: For decrease, increase commands the step needs to be known
  • unit: Unit of measurement (optional). For supported units see OpenHAB: List of Units (opens new window). Examples: "°C", "°F"
# Channel Type "dimmer"
  • on: An optional string (like "ON"/"Open") that is recognized as minimum.
  • off: An optional string (like "OFF"/"Close") that is recognized as maximum.
  • min: A required minimum value.
  • max: A required maximum value.
  • on: An optional number (like 1, 10) or a string (like "ON"/"Open") that is recognized as on/open state.
  • off: An optional number (like 0, -10) or a string (like "OFF"/"Close") that is recognized as off/closed state.
The contact channel by default recognizes "OPEN" and "CLOSED". You can connect this channel to a Contact item. The switch channel by default recognizes "ON" and "OFF". You can connect this channel to a Switch item.
# Channel Type "color"
  • colorMode: An optional string that defines the color representation: HSB, RGB or XYY (x,y,brightness). Defaults to HSB when not specified.
  • on: An optional string (like "BRIGHT") that is recognized as on state. (ON will always be recognized.)
  • off: An optional string (like "DARK") that is recognized as off state. (OFF will always be recognized.)
  • onBrightness: If you connect this channel to a Switch item and turn it on,
# Channel Type "location"
# Channel Type "image"
# Channel Type "datetime"
  • on: An optional string (like "Open") that is recognized as UP state.
  • off: An optional string (like "Close") that is recognized as DOWN state.
  • stop: An optional string (like "Stop") that is recognized as STOP state.
Internally UP is converted to 0%, DOWN to 100%. If strings are defined for these values, they are used for sending commands to the broker, too.
# Rule Actions
val mqttActions = getActions("mqtt","mqtt:broker:myBroker")
where the first parameter always has to be mqtt and the second (mqtt:broker:myBroker) is the Thing UID of the broker that should be used. Once this action instance is retrieved, you can invoke the publishMQTT(String topic, String value, Boolean retained) method on it:
Alternatively, publishMQTT(String topic, byte[] value, Boolean retained) can publish a byte array data.
broker.things file:
mqtt:broker:myInsecureBroker [ host="192.168.0.42", secure=false ]
mqtt:broker:myAuthenticatedBroker [ host="192.168.0.43",secure=true, username="user", password="password" ]
mqtt.things file:
Bridge mqtt:broker:myInsecureBroker [ host="192.168.0.42", secure=false ]
Thing mqtt:topic:mything "mything" (mqtt:broker:myInsecureBroker) {
    Type color : lampcolor "Kitchen Lamp color" [ stateTopic="lamp/color", commandTopic="lamp/color/set", colorMode="RGB" ]
If the availability status is available, it can be configured to set the Thing status:
Thing mqtt:topic:bedroom1-switch (mqtt:broker:myInsecureBroker) [ availabilityTopic="tele/bedroom1-switch/LWT", payloadAvailable="Online", payloadNotAvailable="Offline" ] {
         Type switch        : power        [ stateTopic="stat/bedroom1-switch/RESULT", transformationPattern="REGEX:(.*POWER.*)∩JSONPATH:$.POWER", commandTopic="cmnd/bedroom1-switch/POWER" ]
# Limitations
  • The HomeAssistant Fan Components only support ON/OFF.
  • The HomeAssistant Cover Components only support OPEN/CLOSE/STOP.
  • The HomeAssistant Light Component does not support XY color changes.
  • The HomeAssistant Climate Components is not yet supported.
Received value Tr. Service Transformation
{device: {status: { temperature: 23.2 }}} JSONPATH JSONPATH:$.device.status.temperature
<device><status><temperature>23.2</temperature></status></device> XPath XPath:/device/status/temperature/text()
THEVALUE:23.2°C REGEX REGEX::(.*?)°
Transformations can be chained by separating them with the mathematical intersection character "∩". Please note that the incoming value will be discarded if one transformation fails (e.g. REGEX did not match).
All mentioned channels allow an optional transformation for outgoing values. Please prefer formatting as described in the next section whenever possible. Please note that value will be discarded and not sent if one transformation fails (e.g. REGEX did not match).
# Format before Publish
This feature is quite powerful in transforming an item state before it is published to the MQTT broker. It has the syntax: %[flags][width]conversion. Find the full documentation on the Java (opens new window) web page.
Here are a few examples:
  • All uppercase: "%S". Just use the upper case letter for the conversion argument.
  • Apply a prefix: "myprefix%s"
  • Apply a suffix: "%s suffix"
  • Number precision: ".4f" for a 4 digit precision. Use the "+" flag to always add a sign: "+.4f".
  • Decimal to Hexadecimal/Octal/Scientific: For example "60" with "%x", "%o", "%e" becomes "3C", "74", "60".
  • Date/Time: To reference the item state multiple times, use "%1$". Use the "tX" conversion where "X" can be any of [h,H,m,M,I,k,l,S,p,B,b,A,a,y,Y,d,e].
    • For an output of May 23, 1995 use "%1$tb %1$te,%1$tY".
    • For an output of 23.05.1995 use "%1$td.%1$tm.%1$tY".
    • For an output of 23:15 use "%1$tH:%1$tM".
Type Parameter Pattern Comment
string String "%s"
number BigDecimal "%f" The default will remove trailing zeros after the decimal point.
dimmer BigDecimal "%f" The default will remove trailing zeros after the decimal point.
contact String -- No pattern supported. Always on and off strings.
switch String -- No pattern supported. Always on and off strings.
colorRGB BigDecimal, BigDecimal, BigDecimal "%1$d,%2$d,%3$d" Parameters are red, green and blue components.
colorHSB BigDecimal, BigDecimal, BigDecimal "%1$d,%2$d,%3$d" Parameters are hue, saturation and brightness components.
location BigDecimal, BigDecimal "%2$f,%3$f,%1$f" Parameters are altitude, latitude and longitude, altitude is only in default pattern, if value is not '0'.
image -- -- No publishing supported.
datetime ZonedDateTime "%1$tY-%1$tm-%1$tdT%1$tH:%1$tM:%1$tS.%1$tN" Trailing zeros of the nanoseconds are removed.
rollershutter String "%s" No pattern supported. Always up, down, stop string or integer percent value.
  • If you get the error "No MQTT client": Please update your installation.
  • If you use the Mosquitto broker: Please be aware that there is a relatively low setting for retained messages. If at some point messages stop being delivered change the setting.
