UI components are the basic building blocks for many UIs in openHAB. The Main UI Pages and Personal Widgets are notable UI components, but Sitemaps that were created in the UI and HABPanel dashboards are as well.
  • A type
  • Most of the time, a set of configuration properties
  • Optionally, a set of named slots which hold collections of more components. By putting components into slots, we therefore define a hierarchy. Slots are optional, and have a name; usually when there’re slots involved there’s a default slot but not always.
Sometimes, the slots can be seen as different placeholders within a component where new components may be added. For instance, cell widgets have a header slot which represents the part of the cell when not expanded. The default slot is the space in the cell which becomes visible when the cell is expanded.
In various parts of the UI page designers can "focus" on a particular component usually by selecting the Edit YAML item in a black context menu.
component: oh-type
  prop1: value1
  prop2: value2
  prop3: =expression
    - component: ...
      config: ...
      slots: ...
    - component: ...
  anotherSlot:
    - component: ...
# Root Components & Props
uid: component1
props:
  parameterGroups:
    - name: group1
      label: Property group
  parameters:
   - name: prop1
     label: Prop 1
     type: BOOLEAN
     groupName: group1
     description: What prop1 does
   - name: prop2
     label: Prop 2
     type: TEXT
     context: item
   - name: prop3
     type: INTEGER
     advanced: true
tags: ["tag1", "tag2"]
component: ...
config: ...
slots: ...
  • a uid (its Unique IDentifier)
  • a props structure describing its own properties; props define parameters and parameter groups following a subset of the configuration description schema found in bindings, services and throughout openHAB: see Configuration Descriptions
  • a set of tags
# Widgets: Definition & Usage
  • configure the documented parameters with a config sheet (“Configure Widget” or similar)
  • open the part of the page’s YAML representation pertaining to the widget (“Edit YAML”), that is, a subgraph of the page’s component tree with that widget as its root component
  • perform cut/copy/paste operations, if supported (you can only do that in the same page currently, to copy or move widgets between pages, you may use the YAML view)
  • reorder the widget within its parent slot (these options are usually named “Move Up” and “Move Down” although you may occasionally encounter other labels, like “Move Left”/“Move Right”)
  • remove the widget
Configuring a Widget
  1. not all options are described, since widgets are often wrappers for a similar concept in the library it's based on, either Framework7, ECharts, Leaflet, or other specialized libraries. This means that in these cases, these underlying concepts will usually be passed the key/values of the (openHAB) widget component's config so that more parameters can be accepted than those which are documented in the widget's definition. Sometimes it will be indicated somewhere when configuring the widget, or in the openHAB documentation itself, on the other hand some options won't be available for use (for instance, because they expect a callback function and you cannot define those in the widget's config) or need some transformation.
  2. Sometimes you'll want to use an expression to configure the property, but the UI will get in your way - for instance, it will display an item picker while your intention is to set the prop value to be =props.item1. See below to learn more about expressions.
  3. To quickly and efficiently duplicate similar widgets with only a few differences, it is always way easier to copy/paste the relevant YAML in the editor.
  4. The YAML is the best way of sharing complete or partial component structures like pages or widgets with others in the forum.
  • visible: you can specify a false boolean to this option to hide the widget. This powerful feature, combined with expressions, allows you to dynamically show widgets or even entire sections (if you use it on layout widgets containing other widgets), depending on the state of your items Example: visible: =items.TV_Powered.state === 'ON' && items.TV_Input.state === 'HDMI1'
  • visibleTo: this accepts an array of strings like role:administrator, role:user, or user:<userid>, allowing the widget to be only visible to specific users or those with a certain role. Example: visibleTo: ["user:scott", "role:administrator"]
  • class and style are standard Vue.js attributes (opens new window) and can be used to either alter the CSS classes or add inline styling to the component. See "Styling" below.
# Types of Widgets
  • the System library includes "crude" controls that you cannot add with the designers - for instance oh-button, oh-slider, oh-colorpicker. Instead, you're more likely to use them within some container (card, list item...) provided by a widget of the Standard library; but when designing a personal widget with a complex layout you may want to use one or several of them directly. You may also use them in a slot of another widget, for those which define some, in order to add additional controls to that widget.
  • the Standard library, which has several classes of widgets:
    • layout widgets, examples: oh-block, oh-masonry, oh-grid-row, oh-grid-col that you usually add with the designer to a layout page
    • standalone widgets, examples: oh-label-card, oh-slider-card, oh-player-card - usually not much more than widgets from the System library wrapped in a card
    • list item widgets, examples: oh-list-item, oh-stepper-item, oh-toggle-item - widgets that are thinner than the standalone ones, which you can only add as a part of a list (oh-list or oh-list-card)
    • cell widgets, examples: oh-cell, oh-knob-cell, oh-colorpicker-cell: these widgets are fixed-size cells that you can only add to an oh-cells container widget immediately below an oh-block in a layout page - they will either perform an action - switching a light on & off - or expanding to reveal additional controls
    • page-specific widgets, for instance map pages have oh-map-marker or oh-map-circle-marker, charts have different types of widgets than the rest to represent axes, series etc.
Virtually everywhere - with the notable exception of chart pages - every time you need a config prop to be dynamically updated, you can use an expression to configure it. Expressions are string literals beginning with the symbol = and everything after it is evaluated using a syntax very similar to JavaScript, you can use arithmetic or string operations etc., the conditional (ternary) operator (opens new window), as well as the following objects (subject to evolutions):
  • items is a dynamic key/value dictionary allowing you to retrieve the state of items; the result of items.Item1 will be an object like { state: '23', displayState: '23 °C' } (displayState may be omitted). You can therefore use items.Item1.state to use the current state of Item1 in your expression, if it changes, it will be reevaluated
  • props is a dictionary of the key/values of self-defined props for the current personal widget, or page (pages, like any root UI components, may indeed have props). It is indispensable to use props in expressions when developing a personal widget
  • config is a dictionary of the key/values of the configuration of the current component/widget
  • vars is a dictionary of variables that are available in the component's context
  • loop is a dictionary containing iteration information when you're repeating components from a source collection, it is defined only when in the context of an oh-repeater component
  • the JavaScript Math object (so you can use Math.floor(...), Math.round(...) and the like)
  • the JavaScript Number object (see mdn web docs_: Number (opens new window))
  • the JavaScript JSON object to parse or produce JSON
  • dayjs to build instances of the day.js library (opens new window) that you can use to parse or manipulate date & time
  • theme which holds the current theme: ios, md or aurora
  • themeOptions and device allow to use the relevant objects that you can see in the About page, Technical information, View details, under clientInfo
  • screen returns the Screen (opens new window) object. This allows you to access various information about the current screen, e.g. the available width and height. The two properties viewAreaWidth and viewAreaHeight are added on top. It's recommended to use CSS calc() for dynamic positioning and styling.
  • user returns an object with information about the logged in user: the name (user.name) and an array of the assigned roles for the user (user.roles).
The @ symbol can be used in front of an item name string as a shortcut to the displayState from the items dictionary with a fallback to the raw state:
footer: =@'Switch1'
is the same as
footer: =items['Switch1'].displayState || items['Switch1'].state
Similarly, @@ can be used as a shortcut for just the item state.
Use a filled icon of a lightbulb but only if the state of the items passed in the prop item is ON.
Substracts one week from the state of DateTime and return a relative time representation in the current locale ("3 weeks ago").
# Debugging Expressions
Actions
Action Configuration
# Types of Actions
Action What it does
Navigate to page Opens a different Page with an optional transition.
Send command Issues a command to an Item.
Toggle Item Alternate an item between two states by sending commands (regular command if the item's state is different, or an alternative command if the state is equal to the regular command). Typically used with ON/OFF.
Command options Issues a command to the configured Item based on a comma-separated locally-defined list of options, or on the Item's State Description.
Run rule Trigger a rule directly.
Open popup Open a Page or personal widget in a popup which will be displayed fullscreen on phones and in a 630x630-pixel modal dialog on larger screens.
Open popover Open a Page or personal widget in a small "callout" comic-like bubble
Open sheet Open a Page or personal widget in a drawer appearing from the bottom of the screen.
Open photo browser Displays a full screen interface to view one of several images
Group details Used with Group items to open a popup with an automatically-generated list of the members of the group, represented by their default list item widget. For Groups with a base type like Switch, a standard card widget will also be shown for the Group itself.
Analyze Item(s) Opens the Analyzer window for the specified item(s) and period
External URL Open an external web page
Set Variable Set a variable that you can use in other parts of the page or widget.
In your own personal widgets (see below code snippet), you can define a parameter group with an action context to automatically define implicit props that you can pass "en masse" to built-in components that accept actions with the actionPropsParameterGroup property:
props:
  parameterGroups:
    - name: myaction
      label: My Action
      context: action
  component: oh-button
⚠️ The groupName prefix is the name of the parameter group, but occurrences of the word "action" will be removed from it. If you name the parameter group action there won't be a prefix anymore so the underscore will be removed too.
Group Name Prop Name Examples
action action, actionItem, actionCommand, actionCommandAlt
tapAction tap_action, tap_actionItem, tap_actionCommand, tap_actionCommandAlt
sceneOne sceneOne_action, sceneOne_actionItem, sceneOne_actionCommand, sceneOne_actionCommandAlt
uid: dump_props_as_json
props:
  parameterGroups:
    - name: sceneOne
      context: action
      label: Scene One
    - name: sceneTwo
      context: action
      label: Scene Two
    - name: tapAction
      context: action
      label: Tap Action
    - name: action
      context: action
      label: Tap Action
  parameters:
    - name: prop1
      label: Prop 1
      type: TEXT
      description: A text prop
tags: []
component: f7-row
  tag: pre
    - component: Label
# Variables
Variables are a way to allow more complex scenarios in pages & personal widget development.
  • the variable config parameter of an oh-gauge (read-only), oh-input, oh-knob, oh-slider, oh-stepper, oh-toggle will accept a variable name and control it instead of sending commands to items if set. The "item" parameter can still be set to set the widget to the item's state, when the variable has no value.
  • the varsobject available in expressions (for example =vars.var1 will evaluate to the value of the variable var1).
  • the variable action allows to set a fixed or computed (using an expression) value to a variable.
oh-button & oh-link have a special parameter clearVariable which allows to unset a version when clicked, after performing the action. This is useful when "validating" a variable e.g. send a command to an item with the variable value then reset it.
# Predefined CSS Classes
# CSS Variables
To reuse a CSS variable, use:
    --my-color: =props.color
There are hundreds of CSS properties (opens new window) you can use to design your widgets. Use the resources at W3Schools (opens new window) or the CSS-Tricks Properties Almanac (opens new window) to learn more about CSS properties and techniques - these resources will provide code in HTML and classes definitions but you can most of the time adapt them for usage in components' YAML definitions.
While the Layout components (oh-block, oh-grid-row, oh-grid-col) can help you with the placement of your widgets, to lay out sub-components within a widget, you shouldn't use them because they include design mode controls that you don't need. While can use their f7-block, f7-row and f7-col equivalents instead, in many cases this is still "overkill": consider applying directly the Flexbox or Grid properties to the components.
# Dynamic Styling & Positioning using CSS calc()
You can dynamically style and position elements by calculating their CSS properties with the calc() function. The calc() function is able to perform math (+, -, * & /) on multiple CSS values, which can even have different units.
For example, to set the height of a component to the current page's maximum content height (without scrolling), use the following calc() statement:
calc(96vh - var(--f7-navbar-height) - var(--f7-toolbar-height))
This subtracts the height of the navbar and the toolbar, which are stored in CSS vars, from 96% of the viewport's height.
These resources will help you with calc():
