# Runtime Commands
Query an item's state:
openhab> openhab:status Heating_GF_Corridor
OFF
Changing an item's state:
openhab> openhab:send Heating_GF_Corridor ON
Command has been sent successfully.
Get help for a command:
openhab> help openhab:send
Usage: openhab:send <item> <command> - sends a command for an item
Command Description
openhab:status <item> shows the current status of an item
openhab:update <item> <state> sends a status update for an item
openhab:send <item> <command> sends a command for an item
openhab:items list [<pattern>] lists names and types of all items (matching the pattern, if given)
openhab:items clear removes all items
openhab:items remove <itemName> removes the given item
Command Description
openhab:discovery start <thingTypeUID!bindingID> runs a discovery on a given thing type or binding
openhab:discovery enableBackgroundDiscovery <PID> enables background discovery for the discovery service with the given PID
openhab:discovery disableBackgroundDiscovery <PID> disables background discovery for the discovery service with the given PID
# Inbox
Command Description
openhab:inbox list lists all current inbox entries
openhab:inbox listignored lists all ignored inbox entries
openhab:inbox approve <thingUID> <label> creates a thing for an inbox entry
openhab:inbox clear clears all current inbox entries
openhab:inbox ignore <thingUID> ignores an inbox entry permanently
Command Description
openhab:things list lists all things
openhab:things clear removes all managed things
Command Description
openhab:links list lists all links
openhab:links link <itemName> <channelUID> links an item with to channel
openhab:links unlink <itemName> <thingUID> unlinks an item with to channel
openhab:links clear removes all managed links
openhab:links orphan <list|purge> lists/purges all orphaned - one missing element (either item or channel) - links
# Audio
Command Description
openhab:audio play [<sink>] <filename> plays a sound file from the $OPENHAB_CONF/sounds folder through the optionally specified audio sink(s)
openhab:audio play <sink> <filename> <volume> plays a sound file from the $OPENHAB_CONF/sounds folder through the specified audio sink(s) with the specified volume
openhab:audio stream [<sink>] <url> streams the sound from the url through the optionally specified audio sink(s)
openhab:audio sources lists the audio sources
openhab:audio sinks lists the audio sinks
# Voice
Command Description
openhab:voice say <text> speaks a text on the default audio sink with the default TTS and voice
openhab:voice voices lists available voices of the active TTS services
openhab:voice interpret <command> interprets a human language command
# Automation
Command Description
openhab:script <script to execute> Executes a script from the $OPENHAB_CONF/scripts folder
# Firmware
Command Description
openhab:firmware list <thingTypeUID> Lists the available firmwares for a thing type.
openhab:firmware status <thingUID> lists the firmware status for a thing
openhab:firmware update <thingUID> <firmware version> updates the firmware for a thing
# Users
Command Description
openhab:users list lists all users
openhab:users add <userId> <password> <role> adds a new user with the specified role
openhab:users remove <userId> removes the given user
openhab:users changePassword <userId> <newPassword> changes the password of a user
openhab:users listApiTokens lists the API tokens for all users
openhab:users addApiToken <userId> <tokenName> <scope> adds a new API token on behalf of the specified user for the specified scope
openhab:users rmApiToken <userId> <tokenName> removes (revokes) the specified API token
openhab:users clearSessions <userId> clear the refresh tokens associated with the user (will sign the user out of all sessions)
