# IntelliJ IDE
# Prerequisites
  • git, Maven, IntelliJ and Java 17 are installed
# Install openHAB distribution
  1. Install the official openHAB distribution (opens new window)
  2. Start the distribution in debug mode (use ./start_debug.sh instead of ./start.sh in step 4)
This article refers to the directory where you installed the distribution as <DISTRO_DIR>.
# Build the addons repository
  1. Fork and clone the openhab addons repository (opens new window) into a new directory (Reference <ADDON_DIR> from now on for this article) with git clone https://github.com/<yourgitusername>/openhab-addons (replace git user name accordingly)
  2. Open IntelliJ and create a new project from existing sources (File | New | Project from existing sources) and pick <ADDON_DIR>/pom.xml
    IntelliJ will start importing, indexing and building, it will take while, wait until finished (see status bar)
  3. Use Maven to clean & install the addons project
    • mvn clean install in the root of <ADDON_DIR> using commandline Maven (or IntelliJ Maven view)
    • some of the add-ons might fail to build - if it's not the one, you're interested in that should not bother you
    • when the Maven project finished, you should find the freshly built addon JAR in the target directory
# Debug your addon
  1. Copy the addon JAR to Openhab distribution created before
    • cp target/<ADDON_NAME>.jar <DISTRO_DIR>/addons
  2. The running instance of the openhab distribution should pick up your new addon & start it
    • you can type log:tail in the openhab console to stream the openhab logs
  3. Create a Remote Debug runtime configuration in IntelliJ:
    • open menu Run | Edit configurations
    • click the + sign to add a "Remote" configuration
    • adapt the module setting to the root (org.openhab.addons.reactor)
    • click OK
    • start the debug configuration
    • the IntelliJ console should log: Connected to the target VM, address: 'localhost:5005', transport: 'socket'
Remote Debug Run Configuration
