# Value Storage
  • The values are persisted as a part of the instance of the rule
    • Modifying the rule during development creates a new instance which means the value is reset.
    • Restarting openHAB creates a new rule instance which also means the value is reset
    • In most cases both situations are negligible for many rules.
  • If you need full persistence of values that can be used across rules you need to persist the value in one of the persistence engines like MapDB
  • By default the value is undefined. To check if a value is undefined, use the special "is undefined"-block
value-storage-blocks
# Caching
Since openHAB 4.0 caching functionality was introduced (provided that the rule is using GraalJS / JS Scripting). The blocks have the same behaviour like before when set to "private cache" which means that the value is stores in the rule cache. When storing a value in the "shared cache" the value can be even used beyond the specific rule in a different rule.
value-storage-blocks-cache
# Value Storage Blocks
See also the short video part about youtube Global Value Storage (opens new window)
# Store Value
openHAB 4.0 store-value-cache
store-value
Function: Stores a value under the key name in the specified cache.
# Get Stored Value
Since openHAB 4.0:
blockly-value-get-cache
get-stored-value
Function: Retrieves a stored value by the key name from the specified cache.
# Check if Value is undefined
Since openHAB 4.0:
get-stored-value
value-is-defined
Function: Checks if a value is undefined in the specified cache
example1
example2
