# Logic
One of the most commonly used standard blocks are conditions blocks. More about conditions can be viewed at youtube How to use IF and ELSE (opens new window).
# Math
The Math section mainly consists of standard Blockly blocks. Two new math blocks were added for bitwise operations:
# Bitwise operators
  • bitwise and &
  • bitwise or |
  • bitwise xor ^
  • bitwise left shift <<
  • bitwise right shift >>
  • bitwise unary right shift >>>
blockly-bitwise-operators
# Bitwise invert
Function: The bitwise NOT (~) operator inverts the bits of its operand.
# Rounding
The standard block has been extended to provide a rounding function with the ability to set the number of decimal places:
math-round
# Text
More about that topic can be viewed at youtube Working with Text-Blocks (opens new window).
# CRLF
crlf
crlf
# Text Replace
text-replace
Function: Allows to replace something that is defined by the pattern in the origin-text with what is provided in replacement. Note that the pattern can be just a text or also regex expression.
text-replace example
# Colors
More about that topic can be viewed at youtube Using Color-Blocks and HSB-Conversion (opens new window)
colors-overview
# Color Picker
color-picker
# Random Color
get-random-color
# Create RGB color
create-rgb-color
# Blend two colors
blend-two-colors
this could be used for example with a loop that changes the ratio from 0 to 1 to blend the first color into a second
get-hsb-of
  • use that block and connect one of the above blocks into that one to be able to retrieve the HSB value of that block.
get-hsb-of-example
# Lists
lists-overview lists-overview-concat
blockly-map-for-each
dictionary
dictionary-example
dictionary-getkey
dictionary-getkey-example
# Loop over a dictionary
This block can be found in the Loops section and is a dedicated block that allows to iterate over the elements of a dictionary. The loop provides the value into the variable that was choosen in the drop down. See the examples below how the loop can be used.
map-for-each
Either the dictionary itself can be provided directly or via a variable.
dictionary-foreach-example
# Concatenate lists
Function: adds the second list to the first list and returns a new list
# Loops
Even though there a no specialized openHAB blocks provided, loops are used rather often. Therefore there is a good introduction to loops available which can be viewed at youtube Loops in Blockly (opens new window)
# Functions
A more advanced feature for reusable blockly code is functions. More about that topic can be viewed at youtube Functions (opens new window) and Parameters (opens new window).
