  • Calling Rules or other scripts either located as files on the server or provided via the UI
  • Retrieving attributes provided by the rule context or from the own caller rule.
  • Transforming values via different conversion methods (map, regex, jsonpath)
# Overview of the Run & Process blocks
run-and-process-blocks
# Run & Process Blocks
See also the short video part about youtube Run & Process blocks, transform (opens new window)
# Call Script File
run-script-file
  • No parameters can be provided
See openHAB Call-Script (opens new window) for background information
# Run Rule or Script created in UI
run-rule-or-script
The ruleUID can be found in the list of rules or scripts in the second line of the list (like here helloBlockly or helloWorld) rule-uuid
Parameters are optional:
Notes:
  • parameters can be retrieved in the called script via the "get context attribute"-block (see below)
  • the called rule / script cannot return any value
  • it is not possible to access a particular function in another script or rule as scripts / rules have to be perceived as completely autonomous
  • the called rule / script is run synchronously
# Retrieve context attribute from rule
retrieve-context
retrieve-context-example
# Retrieve rule context information
retrieve-context-info
# Transform values via Map, Regex or JsonPath and others
openHAB provides many transformations (opens new window):
map regex jsonpath
# Example 1: Regex
transform-regex
# Example 2: JsonPath transformation
by using the jsonpath
$.device.status.temperature
transform-jsonpath
# Example 3: Map transformation
transform-map
ON=Ja
OFF=Nein
effects=Effekte
NULL=n/a
hs = Hue/Saturation
ct = Color Temperature
Hue/Saturation
# Inline Script
inline-script
# Example
inline-script-example
See also the short video part about youtube Inline Scripts (opens new window)
