# Item & Things
Items and Things are the major entities of openHAB (opens new window) to control and monitor the home. These can be accessed via the "Items & Things" section of the Blockly Toolbox.
# Item and Thing Blocks
See a video introduction at Working with Items (opens new window)
# Item
never use this block alone as it only returns the items name which alone does not make sense. Instead use the get-Item-Block below.
- Clicking 'MyItem' displays a list of Items to pick from
- Technically this block returns the name of the item as a String.
- As a result, this block can be used wherever the item name is required as a String.
- Learn more about items here (opens new window)
# Get Item
- Clicking 'MyItem' displays a list of Items to pick from.
- Technically this block returns an item object, to be used to retrieve specific attributes using other blocks (see below).
- In openHAB3 this block does not return a String, so it cannot be directly attached to a log-block, as demonstrated below.
- Tip: Often you do want to retrieve the state, hence use the "Get State of Item"-block below
- The block returns the item itself.
# Get State of Item
- Returns the state (opens new window) of an item like ON/OFF, the temperature value etc.
it is recommended in this case to assign this to a variable and use the "String-Append-Text" with an empty "" to convert it into a String for further processing.
See the Item-State documentation (opens new window) for more information
# Get Members of Group
- returns a collection of items which should be used with a for-each-block to loop over the items
- it can be attached to a log-block which would list all items in that block in the form a string representation as follows
- Alternatively you can use the item block var the loop variable to send a command to the items of the group
# Get Items with Tag
Function: Gets all items with the given tags which you can iterate over via a loop
- returns a collection of items which have the given tags
- multiple tags can be provided which then need to be separated with a comma
- if multiple tags are given, the item must have all of the tags ("and"-condition)
If you need an item that has one of multiple tags, then you need to use one block of each and then use the "concatenate list block" (opens new window) to combine the results.
# Get particular attributes of an item
It requires an item object to be connected.
- name: String
- label: String
- state: State
- numeric state: Number
- quantity state: Quantity
- category: String
- tags: Array, e.g.
[plannedTimes]
- groups: Array, e.g.
[plannedTimes, timers]
- type: String
Special handling for Arrays
- they cannot be connected to a block that expects a String (e.g. log-block)
- they must be handled using a for-loop as follows
# Send Command
- value: any state value that is allowed for that item, eg. ON or OFF for a switch.
- Clicking 'MyItem' displays a list of Items to pick one item from
For the difference between send command and post update see "Manipulating States" (opens new window) and "Event Bus Actions" (opens new window).
More about that topic can be viewed at Sending Commands (opens new window)
Item-block examples
Example 1:
- Check if MainSwitch is ON.
- If ON, send ON command to livingroomLight item.
Example 2:
- Get the state of MainSwitch and
- Immediately send it as a command to F2_Office_Main_Light
Ensure that the receiving item can handle the state of the 'sending' item.
# Item Metadata
The metadata blocks provide an easy way of accessing namespace metadata information both for reading and writing. Accessing config metadata on hierarchical levels as well as variable support that allows iteration over computed names is supported (see the examples below).
Note: Metadata blocks are not available for Nashorn but only for GraalJS / JS Scripting.
Here is an expire metadata definition which is visualized as
and modelled in YAML as
value: 0h3m0s
ignoreStateUpdates: "true"
ignoreCommands: "true"
with the blocks that can access it:
There a two different type of blocks:
The value block is the main one for the _value_ of the namespace, which is also directly shown in the MainUI's list of an item's metadata, while the _config_ part holds more complex configuration of that metadata structure below the entry _config_.
The following blocks allow to _change_ the config values in the namespace _expire_:
Here is a definition of a more complex metadata namespace:
```yaml
value: ON
ooone: "123"
oone:
two: "456"
one:
two:
three: "756"
field1: 1
field2: 2
field3: 3
which allows deep hierarchy property access via a configkey-dot-notation like one.two.three
Using variables and loops properties like field1, field2, field3 can even be accessed in a computed way:
# Thing
- Clicking 'MyThing' displays a list of Things to pick from
- Technically this block returns the thingUid of the thing as a String
- Learn more about things (opens new window) or thing-concepts (opens new window)
will write the following into the log
# Get Thing Status
Function: Gets a Thing Status for use in other Thing related functions
- Clicking 'MyThing' displays a list of Things to pick from.
- Technically this block returns a ThingStatus (opens new window) - a String with one of the following statuses
- UNINITIALIZED
- INITIALIZING
- UNKNOWN
- ONLINE
- OFFLINE
- REMOVING
- REMOVED
